Truck running off battery
Discussion in 'Tech Info' started by 98Mounty, Oct 29, 2012.
  1. 98Mounty
    98Mounty Member
    Holbrook NY
    Sounds good can you get a Haynes manual from like an auto store? And I'm going to do that today
  2. cowboy
    autozone stocks them.
  3. iowaredneck
    You can also buy a downloaded version online
    sent from area 51
  4. 98Mounty
    98Mounty Member
    Holbrook NY
    Awesome thank you guys so much ill post back with findings
  5. 98Mounty
    98Mounty Member
    Holbrook NY
    Just to add another thing my alternator is working somewhat as I can leave the car running for an extended period of time and it won't die
  6. Pity7700
    check your battery voltage without the truck running,
    then do a no load test. check the battery voltage while running, it should be between 13-15 volts. total increase should be anywhere from .5v to 2v.
    if it didnt increase the alternator or wiring is bad.
    did you buy a reman'd alternator?
    EDIT: just saw your recent post
    if it passes this test do a load test on it
    bring engine to 2k RPMs and turn on lights, blower, wipers and anything else, battery voltage should increase atleast .5 from the no load test. if it didnt increase .5v or more take it back and replace it.
  7. The Batman
    The Batman Rest In Piece
    cold hill ky
    ok....i see no suggestions for a voltage regulator...i used to have the same problem with an old 78 truck i had...new voltage regulator and problem solved:poker:
  8. Pity7700
    the test could point out a faulty voltage reg if its not charging. the voltage regulators are usually inside the alts on the newer cars though so youd just replace te whole thing
  9. The Batman
    cold hill ky
    meh...just athought:birgits_tiredcoffee
  10. Pity7700
    good chance thats the problem though.
