Truck running off battery
Discussion in 'Tech Info' started by 98Mounty, Oct 29, 2012.
  1. The Batman
    The Batman Rest In Piece
    cold hill ky
    could be the cylinoid.....if its bad it wont show i dont think....:hmm:
  2. Pity7700
    for what? the starter?
  3. The Batman
    cold hill ky
    yup...the nite did that to me...it was bad and it kept draining my system...i replaced it and problem solved.....i did alot of little things like that to it and never posted it...didnt figure it was worth mentioning at the time
  4. Pity7700
    thats an odd one. :jester:
  5. The Batman
    cold hill ky
    i know right.....lol...but it was the problem...:jester:
  6. 98Mounty
    98Mounty Member
    Holbrook NY
    I bought the truck fro a guy who had it sitting within the last year he has replaced the starter alternator and battery. My first assumption was battery so I replaced it under warranty last week and its still doing the same thing
  7. The Batman
    cold hill ky
    check all the little things we told you about
  8. 98Mounty
    98Mounty Member
    Holbrook NY
    So check wiring, voltage, and starter solenoid?
  9. Pity7700
    yup. if you do the test i listed above youll be able to narrow it down and its simple to do. should only take you about 15 minutes to do it. if you have a voltmeter. you may need someone to help you read the meter though if you dont have a pair of jumper leads.
  10. The Batman
    cold hill ky
    yup...starter cylinoid, voltage regulator, and start the truck and pull the hot cable off the battery while its running and see if it dies...that would tell us more than anything...or atleast eliminate the battery all togetrher....do that and let us know...
