Truck running off battery
Discussion in 'Tech Info' started by 98Mounty, Oct 29, 2012.
  1. cowboy
    like it's turning over and not starting or not turning over at all?
  2. The Batman
    The Batman Rest In Piece
    cold hill ky
    cylinoid
  3. 98Mounty
    98Mounty Member
    Holbrook NY
    It's turning over fine just not starting
  4. 98Mounty
    98Mounty Member
    Holbrook NY
    Like for instance when I turn the key it doesn't turn over when I jump it it turns over but doesn't fire
    Can you hear your fuel pump running? Sounds like you need to have a shop run a diagnostic on it....
  6. 98Mounty
    98Mounty Member
    Holbrook NY
    How much would they charge for a diagnostic?
  7. Roush PSD Interceptor
    Have someone turn the key on while you listen at the gas tank for the sound of the fuel pump.
    If ya hear the fuel pump running, then check for spark at the spark plugs/coil pack when cranking engine.
  8. The Batman
    cold hill ky
    mine was turning over fine too....but it was still draining the system
  9. 98Mounty
    98Mounty Member
    Holbrook NY
    Ok ill do that today
  10. 98Mounty
    98Mounty Member
    Holbrook NY
    Alright so I caved and brought it to a shop it ended up being the alternator
