Turn signal problem
Discussion in 'General Discussion' started by thesman727, Sep 8, 2015.
  1. thesman727
    thesman727 Full Access Member
    US
    My turn signals randomly stopped working the other day. I checked and replaced all the fuses to no avail. Any idea what this could be?
    Insert tab A into slot B and........pound it with a hammer!
    Turn signal relay under the steering wheel
  3. Roush PSD Interceptor
  4. Summitrider2012
    Summitrider2012 Junior Member
    Nh
    The stick itself? I had a problem with my wipers and it was that. I'd have to look at an etm but it's a possibility
  5. Darth Bama
    Who needs em, go old school and use your hand signals!
    Sent from my iPhone 6 using Tapatalk
  6. Roush PSD Interceptor
    If it isn't this flasher (the silver canister thingy)
    yours may be yellow,
    then some thing has happened
    inside the steering column on the turn signal
    cams requiring disasembly to repair.
    Am I thinking to far back?
    Or does the all in wonder stick have turn
    signal cams built into the bottom of the
    stick?
    Had to fix the signal cams on my 1974 column.
    Let's hope it is just the flasher.
  7. thesman727
    US
    Yeah I have the silver thingy. I'll try replacing that first and see what happens. I haven't gotten pulled over for not signaling yet so
  8. Roush PSD Interceptor
    Does your hazard lights work, the 4 way flashers?
    If not sure sign it is the flasher gone bad.
  9. thesman727
    US
    My hazards work. And the wiper switch still works along with the high beam switch
  10. thesman727
    US
    Turns out it was the silver thing. Walked up to i-dont-know zone and got me a heavy duty one for $7. Thanks for the help
