TxFx04's Build Thread
Discussion in 'General Discussions' started by TxFx04, Nov 13, 2012.
  1. TxFx04
    Exactly and I have both the impact and badass compressor just no way to compress the sh*t :jester: oh well. The job is 7/8 done. Truck is still running great. Just gotta find time to swap number 8 out
    Sent from my iPad using Tapatalk - now Free
  2. TxFx04
    quick question, my hid fogs stopped working. could the fog light relays be bad? theres a big relay in the fuse panel inside and theres a relay under the hood for fog lights. either that or the ballasts could be fried, they have a little corrosion around the connections. if they relays are bad i'll replace them. just don't want to order new ballasts if that isn't the problem lol
  3. cowboy
    clean the corrison first and give that try first. Then seal the connections in grease.
  4. Roush PSD Interceptor
    Odd that both ballasts go out the same time.
    Check to see if 12 volt power is going to the ballasts.
    That will narrow down where the problem is.
  5. TxFx04
    yeah both stopped working, that's why i thought about the relays going bad, i'll try cleaning
  6. TFIDDLE
    Both my headlights went out when one ballast fried.
  7. AKBray907
    You can bench test a relay real easy too, but I'd check to make sure you're getting the 12v at the lights first before you mess with anything else
  8. ak_cowboy
    That's strange that both would quit at the same time. Check the fuses and relays for sure. You can swap a ballast from your headlights and see if that works also.
    Joe has the right idea. Unplug the fog light harness and make sure you've got 12v to each side first.
  9. TxFx04
    When you say check to see if you got 12v what do you mean lol like a meter?
  10. DestinationFX4
    DestinationFX4 Admanistrator
    College Station, TX
    Use a volt meter to test connection
    Sent from my iPad using Tapatalk HD
