TxFx04's Build Thread
Discussion in 'General Discussions' started by TxFx04, Nov 13, 2012.
  1. TxFx04
    Well that's gay. Looks like ill have to tap into mr. Turn signal!
    Does the power mirror work if you plug it into your truck ?
    You can do some bench testing on the mirror to see
    which one is the led signal if you don't have a wire color code
    with it.
    Take a small metal pin, say a small nail, and push that
    into the mirror connector on the black wire coming out side,
    make sure it is touching the metal crimp connector inside that cavity,
    that way the male/female connector on the other side doesn't get messed up.
    Put it into the black wire presuming black is ground,
    and connect that by a wire to a 12 volt battery ground.
    Take a wire and another small metal pin/nail and make a test probe
    connected to the battery positive 12 volts.
    Probe the positive wire into the red and see what that turns on.
    For safety's sake put a 5 amp fuse on the positive wire just in case
    one of the wire colors you probe is another ground that is connected to the
    black wire inside the mirror.
    If ya connect to the black wire for ground and the red wire to fused 12 volt positive and
    the puddle light or signal led doesn't come on or mirror motors don't move that
    red wire may be the heated glass wire if it has a heated mirror.
  3. TxFx04
    that's a little much lol. and yes the power adjust works perfectly fine
  4. TxFx04
    oh yeah heres ptm mirror caps pchop
  5. yz85rider2002
    Looks good red
  6. TFIDDLE
    redddddddddddddddddddddddddddddddddd
  7. markymark17
    Lockport, NY
    Looks good. Do it up man
  8. cowboy
    Red isn't half bad.
  9. iowaredneck
    Yesssssssssssss!
    sent from area 51
  10. TxFx04
    yall sure it isn't too much?? :hmm: :hmm:
