Unorthodox 4wd dash switch...
Discussion in 'General Discussions' started by Reebers77j, Nov 13, 2018.
  1. Roush PSD Interceptor
    @Reebers77j
    I mean it could be as simple as disassembly of your old switch
    to find the burnt out light and replacement with a compatible replacement ?
  2. Reebers77j
    Reebers77j Junior Member
    US
    the one I ordered only had 2H/4H/4L... said '09.I have seen the one you're referring to and am trying to avoid that one. Online offerings being what they are, I'm hoping I get what they're selling. Figuring if I can get the diagram for the existing, I can meter the corresponding on the new.
  3. Roush PSD Interceptor
    Are we on the same page ?
  4. Roush PSD Interceptor
    Still I don't mind trying to help if you run into any difficulties,
    just send pics or questions here.
  5. Reebers77j
    US
    I can hear that and haven't completely ruled it out. Found this for $20 and a used one for $44. If the old switch opens up safely, I might consider shorting it and using the dash lights below the gauges.
  6. Roush PSD Interceptor
    More than likely it's an incandescent tiny bulb,
    but putting an led replacement in there is also a possibility.
    Like 1,200 ohm 1/4 watt resistor to take voltage down to 3 volts
    for the led lamp.
  7. Reebers77j
    US
    Going to open it up and replace the bulb. Let you know how it goes.
  8. Roush PSD Interceptor
  9. Reebers77j
    US
    Been a while, haven't forgotten you. Haven't played with the switch yet.
    Sent from my SM-G965U using Tapatalk
