Vibration at speed
Discussion in 'Lifted' started by Squirlye, Sep 18, 2019.
  1. Squirlye
    Squirlye Junior Member
    Vail Az
    i recently bought my 09 F-150 supercrew 6'6" bed. It has a brand new 6" rough country lift. After 7 months
    ( the lift was brand new) the truck developed a shimmy/vibration. Mostly felt it in the steering wheel, but if you were a passenger you could feel it too. I took it to the place who put the lift on, for its 500 mile
    Re-torque. They asked if I had any problems or vibrations. I said no because at the time I had none. Fast forward 7 months and now I have a vibration. I then took it back to place who installed the lift. It took them all day to figure out the cause of the vibration. What they came up with is, the struts and shocks are not the right kind for this lift. They recommended going with oil filled. The front are the N2.0 gas filled strut. And the rears are premium N3 shocks gas filled.
    They also said that the carrier bearing is a little out of tolerance. Does any of this sound right. I know that a bad carrier bearing will give you a bad vibration. I had a 78 F-150 with a bad carrier bearing. The shock issue sounds weird to me. Why would they put subpar shocks and struts on this lift. If it was borderline on the type of shocks that worked.Then why not put the best suited for that lift ? The dealership warranty was over after 6 months. I actually bought a extended type warranty. They said they would cover the carrier bearing but not the shocks and struts. The shop said they would upgrade the shocks for me. But I would have to pay for it. I told them I could do that myself and save myself some money. So my question is, has anybody have this same problem ? Also if the shocks weren't suited for that lift wouldn't the vibration start almost immediately
  2. Archilles16
    Archilles16 Junior Member
    CA
    I would personally rule out shocks. If it was the case it wouldnt have taken 7+ months to start giving you a problem
    Sent from my SM-G950W using Tapatalk
  3. Shaggy
    Arizona
    So did you ever get this fixed?
  4. AK SNO RIDER
    AK SNO RIDER Got Snow?
    Soldotna, Alaska
    I'd lean towards it being tires wearing oddly due to the alignment with the lift, or the driveshaft needing balanced or rebuilt, again from the extra angle the lift puts on it.
  5. Shaggy
    Arizona
    Was thinking the same thing.
  6. 4ctNduction
    T-E-X-A-S
    does it vibrate all the time or just at certain speeds ? just my opinion but i dont think very highly of rough country stuff. we have customers come in with all kinds of issues and we usually end up swapping everything. I looked up the kit and it looks pretty basic. spindles, blocks ubolts, spacers, cross members. id see if anyone in your area has a road force machine to put your tires on to check that out.
  7. winterid
    winterid Junior Member
    Phoenix, Arizona, USA
    Same thing happened to be with my old truck but the vibration was caused by my out-of-balance tires.
  8. Squirlye
    Vail Az
    So here is what happened, I called rough country about this problem. They said that I should to take it to a authorized installer, to see what the problem is. I took it to a authorized shop. What the problem was, they had my tires under inflated, and too much negative camber. The tires started to cup and wear too fast. Also the alignment was set wrong. So the they realigned it rotated the tires and put the correct wire pressure. The tires originally weren’t way too low, but low enough to help cause the problem. I was wrong on the original post. I said they wanted me to go with oil filled shocks. But I reread it and they wanted to switch to gas filled. Which is bullshit because that’s what they installed on the truck to begin with. So for $175 I got it fixed and now that the tires are worn down equally it has no vibration.
