Voltage Issues?
Discussion in 'General Discussions' started by HammerDown, Dec 13, 2011.
  1. HammerDown
    HammerDown Pin It To Win It
    Western NY
    I've been having these troubles since I bought the truck,
    1: When I turn the key on, it doesn't do the normal flying guages thing
    2: When the gauges are lit up, they dim down and get brighter when I increase throttle.
    3: With my door unlocks, it doesn't pull the locks up when I hit the button on the remote
    4: Not sure if this is same problem but my heat never gets very hot when I turn the knob
    So is it that the battery is too small or bad alternator or....?
  2. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    I think it could be multiple problems..
    1: the guages arent suppose to sweep the only time mine did that was when I had a bad battery..
    2: Sounds like it could be your alternator
    3: Do they unlock if you hit the switch on the door? if not it could be you acuators
    4: I have no clue about heat and AC lol
  3. iowaredneck
    i would have the battery and alternator checked
    and the heat issue sounds like a blend door problem
