Any Ideas as to what would be causing this? I cant find where the water is coming from. I Figure it may be the heater core? sound right? What do I need to do to fix it?
heater core. my pontiac bonneville just went through the same thing. If you arent using you're heater, you can bypass it w/ a few elbows. This will stop the leaking, but you won't have heat. Rockauto.com for the heatercore.
well....my dads truck is the same way...under the floor mat stays wet....we dont kno where the water is comin from either
