What Tech Info would you like to see?
Discussion in 'General Discussions' started by Nitewolf, Feb 11, 2011.
  1. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    I also have wiring diagrams..
  2. Old_Skl_Raptr
    fuggg!!! were strikin out tonite
  3. rrogers
    well actually it is considered a repair on the lightning
  4. Nitewolf
    Clarksville, TN
    I can check the lightning gimme a sec
  5. Old_Skl_Raptr
    hahaha. good call
  6. Nitewolf
    Clarksville, TN
    2002 5.4L Supercharger Install
    5.4L Supercharger Installation Procedure
    To Install:
    1.Install the CAC.
    2.Install a new gasket.
    3.Install the new bolts.
    4.Install the upper intake manifold.
    5.Install the upper intake manifold and the four rear bolts loosely.
    6.Install the CAC hoses.
    7.Install a new gasket.
    8.Install the vacuum hose.
    Supercharger fastener tightening sequence
    9.Install a new gasket and install the supercharger and plenum assembly, bolts, and the stud bolts. Tighten the retainers in two steps, in the sequence shown.
    • Step 1: Tighten to 2 Nm (18 inch lbs.).
    • Step 2: Tighten 45 Nm (33 ft. lbs.).
    10.Install the two upper vacuum hoses to the supercharger bypass valve actuator.
    11.Install the EGR vacuum regulator bracket and install the nuts.
    12.Position the bracket and install the nuts.
    13.Position the CAC water supply and return tubes and install the nuts.
    14.Install the CAC hoses and the clamps.
    15.Fill the CAC cooling system.
    16.Install the accessory drive belt.
    ***WARNING***
    The throttle body spacer sealing surfaces are soft metals. Carefully clean both sealing surfaces.
    ***NOTE***
    Inspect the throttle body spacer gasket and install a new gasket if necessary.
    17.Install a new gasket and install the throttle body spacer.
    18.Tighten the bolts in two steps.
    • Step 1: Tighten to 10 Nm (89 inch lbs.).
    • Step 2: Tighten an additional 90 degrees.
    19.Connect the vacuum lines.
    20.Connect the brake booster vacuum line.
    21.Connect the vacuum line.
    22.Install the bracket bolt.
    23.Connect the exhaust gas recirculation (EGR) valve.
    24.Connect the vacuum line.
    25.Connect the EGR vacuum tube fitting.
    26.Install the accelerator cable bracket and install the three bolts.
    ***NOTE***
    Pay attention to the throttle return spring orientation. It must be reinstalled in the correct orientation.
    27.Connect the throttle control linkages.
    28.Connect the speed control actuator cable.
    29.Connect the accelerator cable.
    30.Install the throttle return spring to the throttle lever.
    31.Connect the vacuum lines and the vent hose.
    32.Connect the idle air control electrical connector.
    33.Connect the throttle position (TP) sensor electrical connector.
    34.Install the air cleaner outlet tube.
    35.Connect the battery ground cable
  7. Old_Skl_Raptr
    wow. thats the easiest instrictions ive ever read. paired with pics i think an 8 yr old could do it
  8. Nitewolf
    Clarksville, TN
    :D your welcome.. anything else, not too crazy like gears hahahaha
  9. Old_Skl_Raptr
    i would have thought gears would be easier than a s/c hahaha
  10. Nitewolf
    Clarksville, TN
    So how should I do this? should I just amke a new thread and have someone sticky it or do you guys wanna just copy and paste?
