What Tech Info would you like to see?
Discussion in 'General Discussions' started by Nitewolf, Feb 11, 2011.
  1. iowaredneck
    here's one that hasn't been done yet, how about changing the shocks on a 97-03 4x4?
  2. Nitewolf
    Nitewolf The Big Bad Wolf
    Clarksville, TN
    2004-2008 Transmission Removal
    Automatic Transmission Assembly
    Removal & Installation
    To Remove:
    1. Place vehicle in neutral.
    2. Safely raise and support the vehicle.
    3. Remove or disconnect the following:
    • Negative battery cable
    • Transfer case (4WD Vehicles)
    • Transmission fluid pan (if transmission is to be disassembled)
      A) Drain fluid and reinstall pan
    Driveshaft flange marks
    4. Mark the driveshaft flange and rear axle pinion flange (2WD Vehicles).
    5. Remove or disconnect the following:
    • Bolts and rear driveshaft (2WD Vehicles)
    • Fuel line bracket from extension bolt (2WD Vehicles)
    • Shift cable bracket
    • Flexplate inspection cover
    • Rubber access plug
    • Flexplate-to-torque converter nuts
      A) Discard the nuts
    • Starter motor electrical connector cap
      A) Electrical connectors
    • Starter motor
    • Transmission cooler lines and position aside
    • Bolt for the transmission filler tube on RH cylinder head
      A) Position tube aside
    • Bolts for exhaust hanger
    • RH exhaust shield bolt
    • LH exhaust shield bolt Place and secure a transmission jack under transmission. Remove or disconnect the following:
    • Rear crossmember bolts
    • Rear transmission retainer nuts
    • Crossmember
    • Rear transmission support
    Transmission electrical connectors
    • Transmission range sensor electrical connectors
    • Output shaft speed sensor electrical connectors
    • Solenoid body assembly electrical connector Position a drain pan;
    • Insert plug into transmission (if fluid was not previously drained) Remove transmission-to-engine bolts;
    • Note the lengths and locations of all bolts
    ***WARNING***
    Secure torque converter in transmission. Injury can result if it falls out of the transmission.
    Special Tool installation
    6. Install special tool after sliding the transmission back horizontally to provide access.
    7. Lower the transmission nose-down to clear the flexplate and exhaust.
    8. Disconnect vent tube (4WD Vehicles).
    To Install:
    1. Ensure that the special tool is installed.
    2. Position vent tube on top of transmission (4WD Vehicles)
    3. Place and secure transmission on transmission jack.
    Transmission installation with the jack
    4. Raise and position transmission into the vehicle allowing the shaft tail to go over the exhaust, and piloting converter housing into position by dowels in rear of the engine block.
    5. Place transmission in horizontal position and remove the special tool.
    6. Move the transmission toward the engine aligning the orange balancing marks between the torque converter studs and flexplate bolt holes.
    7. Install or connect the following:
    • LH Transmission retaining bolts in correct locations
      A) (as noted during removal)
      B) Torque to: 35 ft. lbs. (48 Nm)
    • RH Transmission retaining bolts in correct locations
    • Solenoid body connector
      A) Connect harness retainer to transmission
    • TR sensor connectors
      A) Torque to: 59 ft. lbs. (80 Nm)
    • Rear crossmember into place
    • Rear transmission support nuts
      A) Torque to: 76 ft. lbs. (103 Nm)
      A) Torque to: 66 ft. lbs. (90 nm)
    8. Remove the transmission jack.
    9. Install or connect the following:
      A)Torque to: 11 ft. lbs. (15 Nm)
    • Bolts connecting exhaust hanger to crossmember
      A)Torque to: 30 ft. lbs. (40 Nm)
    • Transmission fluid fill tube onto RH cylinder head with the bolt
      A)Torque to: 9 ft. lbs. (12 Nm)
    • Transmission fluid cooler tubes
      A)Torque to: 15 ft. lbs. (20 Nm)
    • Starter motor and bolts
    • Starter motor electrical connector and ground wire
    • Torque converter nuts;
      A) (Rotate the crankshaft to access all nuts)
      B) Torque to: 27 ft. lbs. (36 Nm)
      A) Torque to: 25 ft. lbs. (34 Nm)
    • Shift cable end and bracket
    • Fuel line bracket (2WD Vehicles)
      A) Torque to: 18 ft. lbs. (25 Nm)
    • Driveshaft to transmission;
      A) Aligning yellow dots (2WD Vehicles)
    • Driveshaft to rear differential;
      A) Aligning marks, and the bolts (2WD Vehicles)
      B) Torque to: 76 ft. lbs. (103 Nm)
    • New inline transmission fluid filter (or kit if vehicle was not equipped)
      A) Unless no internal repair was performed
    10. Lower the vehicle.
    11. Fill transmission fluid.
  3. Nitewolf
    Clarksville, TN
    The coil springs and shock absorbers right?
  4. deboer03150
    deboer03150 Banned
    Archer, IA (Northwest, IA)
    absorbers
  5. iowaredneck
    yeah
  6. deboer03150
    deboer03150 Banned
    also this should be a sticky
  7. Nitewolf
    Clarksville, TN
    1997-2003 Shock Removal and Install
    Shock Absorber
    To Remove:
    1. Safely raise and support the vehicle.
    ***WARNING***
    Only lower the rear axle enough to access the rear spring.
    2. Support rear axle housing assembly with a jack.
    4. Lower shock absorber bolt.
    5. Upper shock absorber nut.
    6. Shock absorber.
    To Install:
    1. Install or connect the following:
    • Shock absorber
    • Upper shock absorber nut
      A) Torque to: 22-29 ft. lbs. (30-40 Nm)
    • Lower shock absorber bolt
      A) Torque to: 56-75 ft. lbs. (77-103 Nm)
    4. Remove the support jack.
    3. Lower the vehicle.
  8. Nitewolf
    Clarksville, TN
    Not sure if that's what you guys were after... there is another one it says Air Suspension???
  9. iowaredneck
    looks good man
  10. deboer03150
    deboer03150 Banned
    yep
