what the heck is going on with this truck?
Discussion in 'General Discussions' started by Pity7700, Mar 2, 2013.
  1. Roush PSD Interceptor
    blocking bad info
    conspiracy theory
    paranoid
    aliens out to get me
    big brother is watching
    Could be one of many different possibilities. LOL
  2. Pity7700
    :jester::jester:
  3. str8t six
    str8t six never enough
    Back in VA
    the engine idling up and down is from the ac compressor kicking on and off. mine does it too. its from the e fans i guess cause thats when mine started doing it.
    i cant help you with the relay.
  4. Pity7700
    no i know what youre talking about with the ac compressor, this wasnt it. it was rapid as hell.
  5. str8t six
    Back in VA
    maybe check the IAC?
  6. Pity7700
    i just cleaned it.
    it stopped as soon as i shut the heat off but started the second i turned it back on. i pulled out the drive and drove about a block, stopped and turned the heat on and everyhing was fine.
  7. str8t six
    Back in VA
    weird
  8. AKBray907
    Does your radio still work fine? Stations clear? If not you might have interference
  9. Pity7700
    i normally have my phone hooked up to it the radio. ill try turning some stations on.
    im going to run the truck today with out the AUX. power wire hooked up. if that is the problem im going to have to find somerthing to wrap the wire in. i like how clean it looks without that things hanging across the engine.
  10. Roush PSD Interceptor
    If it turns out you see it doesn't continue mayhem on the GEM module
    relays by disconnecting the new route of the aux. power wire
    maybe a Faraday shield over the power wire or around the
    GEM module could solve the interference problem.
    I found some rolled roof patch at Home Depot, rubberized on one side and
    aluminum foil on the other. I was going to use it as a cheap Dynamat
    alternative on my Ranger doors, maybe that would work for a Faraday shield.
    Some practical reality in my tinfoil hat concept.
    :win:
