I'm going back to the track sometime soon.. Wanna hear what some of y'all think the truck will run.. And to do that y'all need specs.. Here I go.. 92 reg cab short bed Flareside. 5.0 .030 overbore Flat tops w/valve reliefs Trick flow track heat 170cc/58cc chamber heads Comp cam XE-264hr-14 pn:35-349-8 Scorpion 1.72 roller rockers Hedman long tube headers 2.5" duals w/magnaflow cats, x-pipe, spintech race mufflers Rebuilt upgraded AOD, factory stall 3.55 rear gears.. I will be doing the ole AOD shuffle to shift gears manually.. Will be leaving at whatever rpm I can rev it to before it breaks tires loose.. Will be shifting around 5300 which is just right before rev limiter.. What do y'all think? Sent from my iPhone 4 using Ford Power
I can tell y'all it'll be faster than 10.59 in 1/8th.. It ran that and everything was garbage on the run... Sent from my iPhone 4 using Ford Power
