yup -12 will look good and work for lift kits
You hafta think about the width of the wheel also to work with a lift not just offset... Like rough country 4-5" needs at the most a 4.5" backspacing to work... on a 10" wide wheel that's a -12mm offset and will work... on an 8" wide wheel 4.5" of backspacing would be +12mm offset and work with the lift... but on a 12" wide rim -12 would be 5.5" of backspacing and won't work with that lift... you'd need at least -38mm offset on a 12" wheel but not too many people run 12" wheels haha but I've seen a few runnin -44... My stock wheels had +25mm offset and worked with the rough country lift that's a 7" wide wheel with 4.5" of backspacing, yes even though thier site says will not work with stock wheels, some stockers do work
