Will Factory HD Wheels fit my F250 XLT?
Discussion in 'Wheels & Tires' started by Sbarnes, Dec 21, 2015.
  1. Sbarnes
    Sbarnes Junior Member
    US
    Hey,
    I love the 20" Harley edition factory F250 wheels, and I know someone that would let them go to me pretty cheap, but I'm curious if the tires would fit (275 65 R20). I have a stock 2004 F250, and previously read that the biggest I could go was 285 75 R16s. Will the HD wheels fit stock with no mods?
    Thanks!
    Spencer
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  2. Bdons-SD
    If the tires on the HD are stock they should fit. What you need to worry about it the offset. If the HD wheels are off of a pre 2005 SD they'll fit, if it's anything off of a truck with the newer front end it will not fit. The front axle on the 2005+ is wider so the wheels have more of a positive offset. Newer stock wheels will sit too far in on an SD with front leafs and the tires will rub at full lock.
  3. TLSF150
    TLSF150 Full Access Member
    Stockbridge, Ga
    Yeah I just put 05+ wheels on my 04 and had to run 2 inch spacers all around to keep them from sticking in to far
  4. Darth Bama
    Get 6" spacers, dat stance life
    Sent from my iPhone 6 using Tapatalk
  5. Shaggy
    Arizona
    So what did you go with?
