Wheel spacers seem like the way to go if they rub, but I can't seem to find any in the 5X135mm bolt pattern that are thinner than 1.3", which would probably be too much, I'm looking for 1/2" or maybe 3/4" thick. Edit: Did find THESE, but they are completely different than a normal spacer in that your lugnut would have 1/2" less threads to hold on too, which to me seems like it could be a problem.
Good looking truck man those wheels look great on it and you don't need to crank the tbars from the way it looks
well if you run too wide of tire the sidewalls are to balloned out. where as you run like a 10 inch wide tire on 8 inch wide rims your side walls don't ballon out so much which thats where you get your max load for the tires. but it your only running them as summer tire and only pull a jetski you'll be fine
YES you can run 33x1250s easily with your wheels ......i run 35x1250s on my stock wheels before .... throw em on there!
