yamahasled's rear end
Discussion in 'General Discussions' started by ranger, Jan 19, 2011.
  1. A7X
    A7X Full Access Member
    Mass
    Look on the axle tag that's bolted onto the diff cover... If ya got the 5.4 I'm sure ya got the 9.75
  2. 79bronco
    79bronco Junior Member
    West Virginia
    I do have the 5.4. Isnt the 9.75 the same size ring gear as a D60?
  3. A7X
    Mass
    The only way you don't have the 9.75 is if someone swapped it...
    Yes the 9.75 is comparable to the Dana 60... it has almost the same size carrier bearings yet the 9.75 has bigger pinion bearings, they have the same size ring gear yet the pinion shaft is bigger in diameter on the 9.75. the 9.75 has only one les spline on each axle shaft than the Dana 60 (9.75=34 D60=35) and the 9.75s axle shafts are 1.29 in diameter and the Danas are 1.36, a minuscule differene
    My 1960 Ford has a Dana 60 in er
  4. 79bronco
    West Virginia
    Thanks! Thats good to know
  5. A7X
    Mass
    Welcome!
