Yeti Build Thread
Discussion in 'General Discussions' started by ak_cowboy, Mar 1, 2019.
  1. ak_cowboy
    Working on the gauge cluster and new fuse box
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    AK SNO RIDER likes this.
    Picked up a hi lift for $40. Ordered a rebuild kit and need to get a handle [​IMG][​IMG]
  3. Roush PSD Interceptor
    Smooth retro fit on the door Will !
    Easy visibility on the gauges.
    Black wire loom next time out for the re-supplies box too.
    Lift jack sweet score !
  4. ak_cowboy
    Yeah, I looked all the wire and have some extras through the firewall already. Been working on getting the trailer plug working. Had to get some fuses, the relay, and a new harness.
  5. Roush PSD Interceptor
    Never enough extra accessories on a truck even with the newest models and their 'upfitter' switches.
    Sent from my SM-G973U using Tapatalk
  6. ak_cowboy
    Got the new 3+1 leaf springs on and new Powerstop rotors, pads, and Napa Calipers on all 4 corners. Got some pics, but not many lol
  7. ak_cowboy
    Couple pics of the spring swap. Had to cut off and replace the front bolts.
    If you dont want to cut them, you have to drop th gas tank and the exhaust [​IMG][​IMG][​IMG]
  8. ak_cowboy
    [QUOTE}New leaf springs. 3+1 to replace the 2+1 that have at least 150k miles on them
    Rear Fenders are roughly 37" off the ground right now. We'll see how much lift these give.[/QUOTE]
    With the new springs installed, and still sitting in the driveway, the drivers side is 39.25" high and the passenger is 40".
    I'm sure they'll settle a little bit, especially once the shell is back on. So I ordered a set of 3" blocks that I'll put on when I level the front.
  9. Roush PSD Interceptor
    The bolt b gone over other tasks most preferred.
    Height no issue, wheel opening front to rear limit now.
  10. ak_cowboy
    Took a 360mi road trip. Did mostly 70 with some 80mph passes. Got 17.2 mpg!
