Im going to redo mine this year. plan is to run a 4ga wire to the fuse block and have everything off of that. which i may make a sealed box so I can put it in the engine bay and have my relays in it too so all i have comeing out of the box is wires to the switches, power in, ground and wires to lights. then have a box inside that will have power to the switches/PA, CB.
yea for sure man. keep an eye on here and see what i end up doing. maybe youll get ideas. i didnt even think about the size wire i should use from the battery to the block. 4awg seems a little over kill. you aint pulling that much amperage are you?
im starting on this project. check out my build thread. im going to post everything there to keep everything i do in one place. http://www.fordfullsize.com/forum/f...why-not-pic-heavy-7208/index6.html#post278925
